Discussion topic: No satellite signal for a few dats
This message was authored by KevinReid1 This message was authored by: KevinReid1
My tv has had no satellite signal for a few days, I've tried cutting it down to one signal but not working either now.
This message was authored by Annie+UK This message was authored by: Annie+UK
Re: No satellite signal for a few dats
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
Annie( I am Neurodivergent ) - Sky Plus FAQ - Sky Stream FAQ
This message was authored by Mark39 This message was authored by: Mark39
If it doesn't recover after switching your Sky box off at the plug for 4 minutes, it's most likely a problem with your dish or cabling. It's worth checking that the dish cables are still securely connected at the back of your Sky box. Beyond that, you'll need to engage a local satellite installer to come and take a look, as Sky no longer provide engineer support for Sky+ boxes, unless you have Sky Protect.
Alternatively, now might be an expedient time to consider upgrading to Sky Q. Any dish issues will be put right at no additional cost, as part of the Sky Q installation.
On average, new discussions are replied to by our users within 100 minutes
