Discussion topic: No satellite signal for TNT Sports
Message posted on 01 Nov 2025 12:33 PM
Subscribed to TNT but getting message 'your Sky+HD box isn't getting a satellite signal'. Other Sky channels seem ok
Message posted on 01 Nov 2025 12:40 PM
Re: No satellite signal for TNT Sports
I'm afraid Sky no longer support Sky+ and Sky+HD set ups (where you've posted).
You'll need to employ a local satellite engineer at your own expense to check/realign/repair/replace the dish/LNB if that's the problem.
If you have Sky Protect cover through Domestic and General Insurance you can call them but a previous post on here stated they wouldn't send an engineer - but they did offer the customer £65 towards arranging one themselves.
The alternative is contacting Sky to upgrade to Sky Q or change to Glass / Stream.
Message posted on 01 Nov 2025 01:17 PM
TNT is one of the first channels to go if your dish is slightly misaligned. Other channels will continue to receive a satisfactory signal. You'll need to arrange a local engineer to take a look as @Daniel0210 posted.
Alternatively now might be a good time to consider upgrading to Sky Q. Any dish or cabling issues will be addressed as part of the Sky Q installation at no additional cost to you.
Message posted on 01 Nov 2025 09:00 PM
@Stokesley1 wrote:Subscribed to TNT but getting message 'your Sky+HD box isn't getting a satellite signal'. Other Sky channels seem ok
Have you tried the SD versions of the channels in the meantime.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
