2
This discussion topic has been answered Discussion topic: No satellite signal, Sky+hd box
This message was authored by: PT14
Tv showing no signal, checked one input only working. Box rebooted both signals return. However when channel selected signal returns to one input only.
I have 2 boxes on multi room and it's the same for both boxes.  Would appreciate any assistance. Paul
This message was authored by: Annie+UK Answer
Re: No satellite signal, Sky+hd box
Check the cables comming in to the Sky Box, unplug them and swap them over
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for PT14
I changed the cables over but that did not work. In order to check the dish on the outside of the house I disconnected it and connected it to a portable one I had. This rectified the fault instantly. Thus showing the fault with the dish on the roof. When this was checked the LNB was showing damaged and open to the elements. Once replaced the boxes were restored to the usual status
