Discussion topic: No satellite signal. I am told it is initialisisng
This message was authored by: AEWatts
On the screen it keeps telling me that it is initialising. This does not happen. A box says Mini TV Unavailable. No satellite signal. The problem started last night when I turned the TV on. I have had no luck this morning.
Re: No satellite signal. I am told it is initialisisng
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
I am NeurodivergentMy F•A•Qs: Sky GlassSky StreamSky GoSky Plus
