3
This discussion topic has been answered Discussion topic: No power going to my sky plus box
This message was authored by: MickeyA
No power going to my sky box
This message was authored by: Mark39 Answer
Re: No power going to my sky plus box
The box has most likely failed, in that case. You'll either need to obtain a replacement yourself, or upgrade to Sky Q. You can find used Sky+ boxes on ebay for around £30. Look for a DRX890 or DRX895 model as they're the most recent.
You mean no lights on the front panel? Have you done the obvious checks?
Avatar for MickeyA
Yes. All usual checks done.
