Discussion topic: New Sky +HD remote doesn’t let me change sound
This message was authored by: Hecate+123
I have a Sky+HD BOX, but the remote was getting a bit battered so bought a new one.... after 3 tries it works ....... except I cannot use it to turn up or turn down the sound which seems a bit odd as it is exactly the same as the old one
Re: New Sky +HD remote doesn’t let me change sound
You have to programme your remote with the correct code for your TV make and model: https://www.sky.com/help/program-your-remote
Avatar for Hecate+123
Level 3 icon
Yes I have done that and everything else works except the sound , as I explained before
Can the remote switch your TV and on off?
