Discussion topic: My sky froze so I have unplugged it and tried to reset it. It says I have no satellite signal
This message was authored by: Michellekelly
My Sky froze so I unplugged to reset it. Now it's saying ....
Your Sky+HD box isn't getting a satellite signal?
Re: My sky froze so I have unplugged it and tried to reset it. It says I have no satellite signal
So far as you can see outside and indoors are the dish cables still intact? Has your Sky box been disturbed recently? How long did you switch it off at the plug for?
This message was authored by: Kevin+Webb
I have followed all the Sky help guides they aere not any use. It would be nice to be able to speak to some body, but that seems impossible. I belive its time sky and I parted company
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
You would need a 3rd party to check your system as it sounds like a hardware failure
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Just to confirm - do you have Sky+? What problem are you having?
