4
This discussion topic has been answered Discussion topic: My sky+ box won't allow watching another channel when recording. I've followed the troubleshooting
This message was authored by: Wes74
and imput won't increase. How do I get a new box?
This message was authored by: Annie+UK Answer
Re: My sky+ box won't allow watching another channel when recording. I've followed the troubleshoot
Sounds like a signal issue 😞
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
If this has just started to be an issue what are you signal strengths like, these can be found via settings > signal.
There are two dish connections at the back of your Sky box. Do both of them have a cable connected?
Avatar for Wes74
Yep and I've unscrewed and eschewed them but the input level is not increasing
