Discussion topic: My sky+ box isn’t getting a signal
This message was authored by: Ellyellyelly6
My tv is not getting a signal.
my Netflix and all other services work. But my sky box is not
Re: My sky+ box isn’t getting a signal
Please Note: Sky+ is now a legacy service that Sky are winding down
"No Satellite Signal" is an error generated by your Sky box and usually indicates an issue with one or more of the following:
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
Avatar for Ellyellyelly6
Level 0 icon
I hate this system.
my sky+ box is t working. All my other services are working. Just not sky
@Ellyellyelly6 wrote:
I hate this system.
If you're seeing a 'no satellite signal' it has nothing to do with the broadband your other devices use. It means there's a problem with your dish setup. See @Annie+UK's post for what to do.
