Discussion topic: My sky box has not been receiving signal on the channels for a month
This message was authored by: Mathoda
My sky box has not been receiving signal on the channels for a month On some of the channels now it is not receiving signal on any channels. We cannot use sky
Re: My sky box has not been receiving signal on the channels for a month
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q, Sky Glass and Sky Stream
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
