3
This discussion topic has been answered Discussion topic: My sky + TV box won.t connect to my router.
This message was authored by: broncos1161958
I can still watch sky tv but my catch up has gone, my TV listings don't work and there is an on screen message saying connect sky box to router. I have trted the wps button at the side of my router ,pushed it for 2 seconds, then press the WPs button on my Sky + HD box which flashes yellow, but does not connect??!! What can I try.
This message was authored by: Annie+UK Answer
Re: My sky + TV box won.t connect to my router.
Turn off your router and Sky Box for a coupe of minutes, then turn on the router and wait for it to fully start, then do the same for your Sky box
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for broncos1161958
Thanks Annie, I will try that. 🙂
Thanks Annie. That worked. i will remember this for next time it happens. Cheers
