8
This discussion topic has been answered Discussion topic: My sky HD+ remote won’t sync to my new Panasonic TV
This message was authored by: DrDub
I have a version 10 remote which has previously worked with a Toshiba and a Phillips TV. I've just bought a new Panasonic and I can't get any of the codes on the Sky website to work. Any ideas? Thanks
This message was authored by: Mister_Dalek Answer
Re: My sky HD+ remote won’t sync to my new Panasonic TV
@DrDub
Try some of the Vestel codes. Many of the cheaper Panasonic TVs are manufactured by them now.
Tried 0680?
Avatar for DrDub
Indeed, I have and no joy.
@DrDub
If all else fails, How to program your remote control with no code.
See question Q43 in my Sky Plus F⋅A⋅Q
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for DrDub
Hi. Thanks for that. 1191 did the trick!
This message was authored by: Trishmac
Hi. I have a new Panasonic tv tb55w60aey.
I cannot get any code to work my sky+hd rev 10 to work my tv. I've tried everything! Finally used the link for programming without a code and i managed to get it partially working. Works Sky will turn tv off but not on..or work the volume. Thanks for your advice. Regretting getting this tv now 🫤 x
Take a look at the link below:
Thanks Annie. That's the link I used  that finally got it partially working. Guess I'll have to live with that lol x
