Discussion topic: My sky+HD box isn't getting a satellite signal
This message was authored by: Arifskhan
Avatar for Arifskhan
Level 0 icon
Re: My sky+HD box isn't getting a satellite signal
Can you please help me
Switch your Sky box off at the plug and check the dish connections at the back of the box. Leave the box switched off for 4 minutes. If the dish connections are secure, and the problem remains after switching on again, it looks like a fault with your dish setup.
Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect so you'll need to engage a local satellite engineer to take a look for you. If you're connected to a communal dish, speak to your .landlord or their managing agent.
