20 Nov 2023 09:19 AM
My Sky remote control isn't working. I have internet but the TV is stuck on ITV
20 Nov 2023 09:57 AM
Posted by a Superuser, not a Sky employee. Find out moreHave ypu restarted your Sky box? Turn it off at the plug for 4 minutes.
20 Nov 2023 10:12 AM
Hi Mark
Thanks for the reply. I have rebooted it several times. I have changed the batteries but still not working. Thanks for your help anyway. 👍
20 Nov 2023 10:27 AM
Posted by a Superuser, not a Sky employee. Find out moreHi @Gary591 just to confirm - this is Sky+, not Sky Q or Sky Stream? Does your remote still change,the volume on your TV (assuming you had previously programmed it to do so)?
20 Nov 2023 11:42 AM
Hi Yes it is Sky + and Yes it controls the Volume only. It does not respond to the menu command or the programme up and down button. There is no red LED light either? Thanks again Gary
20 Nov 2023 01:17 PM
It sounds as though the remote may have failed. You can check by pointing the end of the remote at the camera on your mobile, and pressing one of the buttons that controls your Sky box - try the blue Sky button. If the remote is working, you'll see pulses of white light on your mobile's screen.
20 Nov 2023 01:25 PM
Just to check, now as you have rebooted the Sky box, is it stuck on channel 998 rather than ITV? If it's still on ITV that suggests the TV in on the wrong input.
20 Nov 2023 05:46 PM
Posted by a Superuser, not a Sky employee. Find out more@Gary591 Do the buttons on the top of the box work?
On average, new discussions are replied to by our users within 100 minutes
