Discussion topic: My old Sky box keeps getting technical fault and stops recording programs I try to record,
This message was authored by: ReginaldK
Knowing my Sky box is very old and cannot remember our long I been member of Sky,
would it be possible to get Sky engineers to come to my home and and fix my sky box
Re: My old Sky box keeps getting technical fault and stops recording programs I try to record,
Sky only send "engineers" for Sky Q an Sky Glass TV systems, you would need to contact a 3rd party to check your system
It might be cheaper to get a secondhand replacement box from somewhere like eBay
I am NeurodivergentMy F•A•Qs: Sky GlassSky StreamSky GoSky Plus
@ReginaldK
As stated Sky no longer support Sky+ box issues. You will either need to
purchase a new box from somewhere like eBay
upgrade to Sky Q or
employ a local satellite engineer to come and look at your set up
(if you have cover with Sky Protect through Domestic and General Insurance contact them).
