Discussion topic: My f1 channel is not working
This message was authored by: FionaMiller26
All other channels are working despite message on f1 site saying no satellite signal
Re: My f1 channel is not working
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
Try turning your Sky box off at the plug for 4 minutes. If that doesn't resolve, the most likely cause is a slight dish misalignment. Unfortunately there's no longer any engineer support for Sky+ unless you have Sky Protect, so you'll need to engage a local satellite engineer to take a look.
