Discussion topic: “Mini tv signal loss” on some channels
Message posted on 28 Dec 2024 01:53 PM
I have a Sky+HD box and receiving "mini tv signal" error on some channels. Like BBC2 Channel4, however the +1 channel for each of the lost channels does work.
I have reset my box and left it off overnight and still to no avail.
Message posted on 28 Dec 2024 01:58 PM
Re: “Mini tv signal loss” on some channels
Sounds like a signal problem on one of your dish cables. Try turning your Sky box off at the plug, then checking the dish connections at the back of the box to make sure they're still securely fitted.
Message posted on 28 Dec 2024 02:00 PM
I have checked those connections too with no change sadly
Message posted on 28 Dec 2024 02:13 PM
You'll need a satellite engineer to take a look then, I'm afraid. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you would need to engage a local installer.
Or now might be a convenient time to upgrade to Sky Q or Sky Stream.
Message posted on 28 Dec 2024 02:15 PM
Ok, thank you, how do I book an engineer to come look at it?
Message posted on 28 Dec 2024 02:20 PM
Do you have Sky Protect?
Message posted on 28 Dec 2024 02:22 PM
I don't believe so, no.
Message posted on 28 Dec 2024 02:30 PM
You'll need to look for a local satellite installer to check it for you.
Message posted on 28 Dec 2024 04:37 PM
@Johnlyons wrote:Ok, thank you, how do I book an engineer to come look at it?
On google maps search for "satellite installer"😉
