Discussion topic: Mini tv not available. No satellite signal
Message posted on 11 Aug 2025 01:35 PM
Have been watching on this set up for over 20 years. Yesterday afternoon it just stopped working and gave the above error message. The dish seems ok. All wires are connected. Have switch off and switched back on after 1 hour. I still get the same message.
Message posted on 11 Aug 2025 01:49 PM
Re: Mini tv not available. No satellite signal
The cause is most likely a fault with your dish or cables. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you'll need to contact a local satellite engineer to take a look.
Alternatively now might be a good time to consider upgrading to Sky Q. Any dish or cabling issues will be addressed as part of the Sky Q installation at no additional cost to you.
Message posted on 11 Aug 2025 06:04 PM
@Ad50 If you look at your Signal Strengths in Services > Settings > Signal I'd hazard a guess that one of the Inputs isn't getting a signal.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
