Discussion topic: Message on tv saying no signal. Unable to access channels. Need help to fix this. Message on tv sayi
Message posted on 09 Dec 2023 02:07 PM
Message posted on 09 Dec 2023 02:13 PM
Re: Message on tv saying no signal. Unable to access channels. Need help to fix this. Message on tv
To clarify:
'no signal'?
Or 'no satellite signal'?
Message posted on 09 Dec 2023 02:16 PM
No signal
Message posted on 09 Dec 2023 02:19 PM
Check that your TV is switched to the HDMI port that your Sky box is connected to. Then restart your Sky box by switching off at the plug for at least 4 minutes.
If that doesn't fix it, there's may be a problem with the cable between your Sky box and TV. WIth both your TV and your Sky box in standby, disconnect the cable, swap the ends over and reconnect it. Then try again.
Message posted on 09 Dec 2023 02:30 PM
You also posted this on the Sky Q board (since removed) so can you confirm which you have - Sky+ or Sky Q?
Message posted on 09 Dec 2023 02:38 PM
You have again posted on the Sky Q board. This time you've confirmed you have Sky+HD and NOT Sky Q so no point in you posting there. It has again been removed. You have this thread. You also said that the message says no satellite signal whereas on here you've said no signal ~ so which is it?
Message posted on 09 Dec 2023 03:01 PM - last edited: 09 Dec 2023 03:37 PM
"No Satellite Signal" is an error generated by your Sky box and usually indicates an issue with one or more of the following:
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
