6
This discussion topic has been answered Discussion topic: Message on screen saying ‘there is a problem with the hard disc drive fault’
This message was authored by: NealB2024
Re: Message on screen saying ‘there is a problem with the hard disc drive fault’
@NealB2024
Try a planner rebuild:
Press Services on your remote
Select Help
Select Sky+ Rebuild
This should take no longer than 10 minutes,
@NealB2024
Select Help
Select Sky+ Rebuild
See question Q14 in my Sky Plus F⋅A⋅Q
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for NealB2024
I have passed on your advice to the person at the home address.  I will reply with an update shortly
Thank you
Neal
We have tried this but ithas not worked
Also followed the next step, turn off and restart, still will not allow any recording
@NealB2024 as a last resort you could try a System Reset (it's in the same menu as a Planner Rebuild). If that doesn't restore normal working, I'm afraid the hard disk has died and the box will need to be replaced. There are used boxes available on ebay etc for around £30 (DRX890 and DRX895 models only), or now might be the time to upgrade to Sky Q.
Thank you, will give this a try
If not, I guess its time to upgrade to Sky Q
