5
Discussion topic: Lost of satellite signal on tv as soon as a programme records
This message was authored by aql0560 This message was authored by: aql0560
When I start to record a programme I lose satellite signal and there fore I can not watch TV whilst the programme is been recorded.
This message was authored by Mark39 This message was authored by: Mark39 Answer
Re: Lost of satellite signal on tv as soon as a programme records
You have no signal on dish input 2. Assuming you have two cables from your satellite dish, check that both are still properly connected at the back of your Sky box. If all looks OK, restart the box by switching off at the plug for 4 minutes. If it's still unresolved,  give Sky a call to book am engineer.
Do you live in a flat, if not what are your signal strengths like, this can be found via Settings > Signal.
aql0560
No don't live in a flat
aql0560
Mark39,cheers for your advice.Sorted.input 2 was loose.Thanks.
Glad you were able to fix it easily 🙂
On average, new discussions are replied to by our users within 100 minutes
