4
This discussion topic has been answered Discussion topic: Loss of signal
This message was authored by: Michelle1100
Loss of signal
We've detected a problem with the signal
This message was authored by: Annie+UK Answer
Re: Loss of signal
No Signal or No Satellite Signal?
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
Re: Loss of signal
Avatar for Michelle1100
Level 0 icon
Re: Loss of signal
I have loss of signal
no satellite signal
Re: Loss of signal
no satellite signal
If you have Sky+ then it's up to you to sort out the signal issue because Sky no longer support Sky+.
Check the cables at the back of the box and make sure they are tightly screwed on. If you still have issues you'll need to contact an independent satellite installer at your own expense to check your dish and cabling.
Alternatively, it might be time to think about switching to Sky Q or Sky Stream.
Re: Loss of signal
@Michelle1100
Then the answer provided by @Annie+UK applies.
