This discussion topic has been answered Discussion topic: Interference of television picture.
Message posted on 09 Oct 2023 07:52 PM
Hello.
ive been getting interference on my television. I have sky+HD. The TV is contected via a RF cable. Its the onky way I can connect the box to the Tv. Always had no problem over the years, then all of a sudden the past few weeks been getting this issue. I have checked all the conextions, even bought new RF cable which I am now using. Problem tends to be worse at night time for some reason.. every time I soeak to sky I get a different potential answer from needing new cabkes to interference from 5G. Have added video showing the interference. Any help apreciated. Thanks. Steve.
Message posted on 09 Oct 2023 08:26 PM
Change the RF Output Channel in your Sky box settings. If you're currently using the default channel 68, it's entirely possible that the adviser was correct and it's due to cellular interference. Once you've changed the RF Output Channel, you'll need to re-tune your TV to pick up the new channel.
Message posted on 09 Oct 2023 10:25 PM
Re: Interference of television picture.
Thank you. That does appear to have the problem.
Steve.
