Discussion topic: I’ve reported no satellite signal - the dish is rusted away
Message posted on 05 Feb 2025 07:32 PM
Sky keeps saying they are trying to work out what's wrong with my signal - 72 hours max then another 72 - I've discovered the dish is totaly broken but can't
Message posted on 05 Feb 2025 07:39 PM
Re: I’ve reported no satellite signal - the dish is rusted away
Although Sky themselves no longer support Sky+ and Sky+HD, if you have Sky Protect through Domestic and General Insurance you can call them otherwise you'll need to employ a local satellite engineer at your own expense to check it (or upgrade to Sky Q or change to Stream or Glass).
Message posted on 05 Feb 2025 07:49 PM
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
