Discussion topic: I'm getting an error message saying no satellite signal - sky hd
Message posted on 26 Sep 2024 01:59 PM
I've had an error message for 4 days saying no satellite signal. I've tried resetting the box, unplugging it and then plugging it back in but nothing. What do I need to do to get the box to start working again?
Message posted on 26 Sep 2024 02:04 PM
Re: I'm getting an error message saying no satellite signal - sky hd
Almost certainly a dish misalignment. Although Sky themselves no longer support Sky+ and Sky+HD, if you have Sky Protect through Domestic and General Insurance you can call them otherwise you'll need to employ a local satellite engineer at your own expense to check it (or upgrade to Sky Q or change to Glass / Stream).
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
