Discussion topic: I have issues with ny sky box and remote
Message posted on 21 Sep 2023 03:04 PM
I have issues with my sky+ box and remote control
Message posted on 21 Sep 2023 03:05 PM
Re: I have issues with ny sky box and remote
What are they?
Message posted on 21 Sep 2023 03:07 PM
My remote buttons need to be pressed very hard for it to change channels on the sky box.
Also i can only record 1 programme at a time and im unable to change the channels
Wheras before i can record 2 programmes and change channels
Message posted on 21 Sep 2023 03:10 PM
With regard to your remote, it's probably simplest to replace it. They're available at reasonable price from hardware stores and even supermarkets.
For the box itself, it sounds as though you're only receiving a signal on one of the dish inputs. Check your signal strengths (Services > Settings >Signal). The white part of all four bars should be at least half way across.
Message posted on 21 Sep 2023 03:12 PM - last edited: 21 Sep 2023 03:15 PM
Clean the remote control, See Q26 of my Sky Plus FAQ 🙂
Message posted on 21 Sep 2023 03:13 PM
Thanks for the reply. I have checked the settings signal.. all seems well im currently on the phone to them.. been on hold for 27 minutes
