Discussion topic: I have a new tcl tv and i cant get sky can anyone help my remote hasnt got and codes on it
This message was authored by nikkit40 This message was authored by: nikkit40
This message was authored by Mark39 This message was authored by: Mark39
Re: I have a new tcl tv and i cant get sky can anyone help my remote hasnt got and codes on it
Have you tried the codes here: https://www.sky.com/help/program-your-remote
This message was authored by Morph88 This message was authored by: Morph88
Hi had the exact same problem and found the solution by looking at a number of sites, go to the set up remote control menu, enter the brand JVC, then press find it for me, will give 1-27 settings, try each one, mine worked on option 17. Hope this works for you
On average, new discussions are replied to by our users within 100 minutes
