Discussion topic: I have a message saying I have no satellite signal for my sky service
This message was authored by: Tredavoe
Re: I have a message saying I have no satellite signal for my sky service
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Switch your Sky box off at the plug for 4 minutes. Check that the dish cables are securely connected at the back of the box while it's turned off. If you still have no satellite signal when you turn it back on, you'll need someone out to take a look at your dish setup. Unfortunately Sky no longer provide engineer support for Sky+ boxes unless you have Sky Protect, so you'll need to get a local satellite installer to take a look.
