Discussion topic: I had no signal for ages i followed the instructions on the sky ap now my sky is saying my sky box i
This message was authored by: Jan13037
I have had issues with sky first of all I had no signal, I followed instructions on my sky box, now it is initializating, I can't do anything with it, it's been like this for days, even when I turn it of and back on its still initializating
Re: I had no signal for ages i followed the instructions on the sky ap now my sky is saying my sky b
"No Satellite Signal" is an error generated by your Sky box and usually indicates an issue with one or more of the following:
• The Dish is misaligned
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
