3
This discussion topic has been answered Discussion topic: I can’t connect my sky box to my tv as the sky box is too old
This message was authored by: Andy238
My sky box is to old to connect to my tv.  I need a replacement.
This message was authored by: Annie+UK Answer
Re: I can’t connect my sky box to my tv as the sky box is too old
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
You can get a secondhand Sky+HD box from the likes of eBay etc...
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
I'm guessing you have an old Sky+ box. Sky no longer provide Sky+ or Sky+HD boxes. You can obtain a used box cheaply via ebay etc. Look for a DRX890 or DRX895 model as they're the most recent, though still at least 8 years old. You'll need to keep your Viewing Card to use in the new box, and will then need to link the two.
The alternative would be to upgrade to Sky Q.
@Andy238
It's possible to purchase an adapter which converts SCART output to HDMI input, but your eyeballs won't thank you for it.  An LCD television (even if just HD rather than UHD) really deserves better than an interconnect which is now half a century old.
