Discussion topic: I am not receiving some channels but am receiving others
Message posted on 26 Nov 2024 06:03 PM
My sky box is working it has been reset and power turnt off but I can still only receive some tv channel's and some that say no signal??
Message posted on 26 Nov 2024 06:07 PM
Re: I am not receiving some channels but am receiving others
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Message posted on 26 Nov 2024 06:11 PM
Thank you for your reply but why am I receiving certain channels and not others doesn't make sense??.
Message posted on 26 Nov 2024 06:14 PM
See the first bullet point in my post above
