Discussion topic: I am not getting a signal to my sky hd box
This message was authored by: RoyFeaviour
I am unable to watch the TV because I am not getting a signal
Re: I am not getting a signal to my sky hd box
No Signal or No Satellite Signal?
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
