Discussion topic: I am not getting a satellite signal on some of my channels
This message was authored by: sandmar22
Hi there I can't  get access to some of my channels as it says I have no satellite signal on these channels it seems to be affecting the QVC channels
Re: I am not getting a satellite signal on some of my channels
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
