46
This discussion topic has been answered Discussion topic: How to pair sky viewing card to Sky+ box
This message was authored by: Tina551
I used to use Sky.com/quick fix to pair sky viewing card to another box (still at main address) this page no longer seems to be available and any link I have found (activate etc) just loops back to the first page with no opportunity to add any details.  The only customer service number I found sent me a link to this help forum!
Help would really be appreciated!
Thank you.
This message was authored by: Quoman7 Answer
Re: How to pair sky viewing card to Sky+ box
Thank you.
Hi @Tina551 It has recently come to our attention that :- From 29 October, you won’t be able to pair a viewing card to new/different Sky+ or Sky+HD boxes.
You will need to call SKY and talk to an advisor with regards to updating to either SKYQ, SKY Glass or SKY Stream.
Avatar for Tina551
Thank you Mark for the quick response, unfortunately that link seems to be broken, it just keeps looping back to previous page! I am wondering if Sky longer supports this as the Sky+ box is quite an old system! But I still need to pair the card!
Try performing a New Install
See question Q21 in my Sky Plus F⋅A⋅Q
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
Avatar for Tina551
Thank you for your reply but the box is not connected to the internet or phone line, do you know the telephone number to call? And out of interest do you know what happened to the Sky.com/quickfix option? That was so simple!
Use the following link for contacting Sky: CONTACT
A phone number is given on a link on the page linked to below (click on the "Need more help?" drop down):
There is also Sky's How can we help? page
(make sure the correct country is selected at the bottom of the page)
Avatar for Tina551
Thank you very much Annie, I will try to phone them tomorrow!
This message was authored by: Rikkidog
Hi , I've the same problem,  I'd be interested in finding out how you get on regarding a solution.
Avatar for Tina551
I will certainly post on here if I manage to resolve this!  I have a telephone number but really had other things to do today other than put myself in a queue! I rather suspect that if I threaten to cancel my Sky subscription, I might get an answer!
Hopefully that threat should do the trick 🤞
Thank you.
Are Sky going to make a public statement about this change🤔
I would guess that's unlikely, presumably on the basis that Sky+ is a legacy product, no longer marketed and increasingly unsupported.
Avatar for Tina551
Thank you all who replied to this problem!  I think I now have my answer, time to give up or give in and upgrade!
So Sky is happy for subscribers to buy replacement Sky+ HD boxes only to find they can not be activated😔
