5
This discussion topic has been answered Discussion topic: How to find out Sky+HD box recording capacity?
This message was authored by: akh48
I am looking to cancel Sky in the next few days due to price increase of over 10% and looking to replace with a new recording box, but want to make sure I get a big enough capacity and not 100% sure what my current box size is.
When I googled I only found 250GB is that the only size of a Sky_HD box?
Is there a way to check the recording capacity on my box?
Not sure what model I have when I check the system details it just says R024.092.11.00P next to Model Number in settings.
Can anyone recommend a good replacement box for the Sky+HD?
BRING BACK SKY NEVER MISS
This message was authored by: Annie+UK Answer
Re: How to find out Sky+HD box recording capacity?
That mdel has a 500GB HDD with 250GB reserved to Skys use, thus 250GB for the users recordings/downloads
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
The sizes are 250GB, 1000GB or 1500GB dependig what your model of box is look for a sticker on the box for a DRX number, the number you have given is the software version
Avatar for akh48
Level 5 icon
Eventually managed to find it hidden underneath it is: DRX890WL-Z
@akh48 it might be more useful to consider the content the disk can hold.
The user manual says that a DRX890 can store 180 hours of SD content and 60 hours of HD content.
Avatar for akh48
Level 5 icon
sorry missed annie's answer with the disc size above your post, but can't delete my post.
