12
This discussion topic has been answered Discussion topic: How do I connect my Sky+HD box to my broadband router using WiFi? I cannot access catch up etc
This message was authored by: Sue31849
I have a message on my screen saying I cannot access Catch Up or other facilities on my Sky+HD box without connecting to my broadband. How do I do this preferably using WiFi as the router is too far away to use a cable.
This message was authored by: Mark39 Answer
Re: How do I connect my Sky+HD box to my broadband router using WiFi? I cannot access catch up etc
@Sue31849 wrote:
@Mark39
Yes my box does have a WPS button. What do I now do?
That's good news, as it means your Sky box has wifi capability, as @TimmyBGood posted. All you need to do is press the WPS button on your Sky box and then within 30 seconds press the WPS button on your broadband router (if it's a Sky router, it may be on the side). Providing your router and Sky box are within wifi range, it will connect automatically after a minute or so.
Does your Sky box have a 'WPS' button on the front panel?
@Sue31849
As @Mark39 indicates, if the Sky box has a WPS button then that indicates it has built-in WiFi.
https://www.youtube.com/watch?v=xtT9RFMsU9Y
If it doesn't then extra hardware (a 'Sky Mini Connector') is required and you'd have to source that second-hand because Sky no longer supplies such things.
Avatar for Sue31849
@Mark39
@Sue31849 wrote:
@Mark39
Avatar for Sue31849
@TimmyBGood
@Mark39
Thanks Guys - all set up now!!!
Sue31849
This message was authored by: Brevanic25
When I go to services settings and network I can't go any further and it says connection to broadband router and on demand fail
@Brevanic25 use the WPS button, as described in the post marked as the Answer.
This message was authored by: Bible1
No
tried this numerous times without success
@Bible1 wrote:
No
Use an Ethernet cable to connect the two together
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
@Bible1 does your Sky box have wifi capability?
Yes I have a Wi-Fi  connection but I do not have broadband connection
Tried this numerous times - still get the same manage
