Discussion topic: Hisense 43 Inch VIDAA Smart TV 43A6KTUK
This message was authored by: tim11669
Hi all..
Looking for a code for the sky rwmote so it will work the above model. The common codes dont work
Thanks in advance
Tim
Re: Hisense 43 Inch VIDAA Smart TV 43A6KTUK
@tim11669
Any known codes will be shown here:
https://sky.uebv.com/
If you can't find one then try this:
1. Press TV
2. Press and hold Select and Red together until the red LED flashes twice.
3. Press TV, then Standby repeatedly until the TV switches off. As soon as it switches off, press Select to save the code.
@tim11669 the procedure described by @caesarome goes through every code stored on the chip in your remote, so it's a laborious process. If your TV doesn't respond to one or more of them, there's no code for it.
