This discussion topic has been answered Discussion topic: Hi can anyone help i have the old sky plus box and it wont let me record anything
Message posted on 18 Jul 2023 07:28 PM
Hi can anyone help i have the old sky plusbox and it wont let me recod it just keeps saying failed
Also wont let me pauselive tv or rewind etc
Message posted on 18 Jul 2023 09:35 PM
Unfortunately when you order Sky Q your Sky+ Viewing Card is automatically scheduled to be disabled. That isn't reversed when you cancel, hence the errors you're seeing now. If you received a Viewing Card for the Sky Q, you can use it, otherwise you'll need to contact Sky for a replacement card, I'm afraid.
Message posted on 18 Jul 2023 07:39 PM
Re: Hi can anyone help i have the old sky plus box and it wont let me record anything
Highlight a failed recording in your Planner and press i on your remote. The failure reason will be shown at the end of the programme synopsis - what does it say?
Message posted on 18 Jul 2023 07:45 PM
Many thanks
It says recording failed subsciption needed
Message posted on 18 Jul 2023 08:06 PM
Which Sky TV subscription package do you have? Is this a replacement box? Have you been able to record ok before?
Message posted on 18 Jul 2023 08:14 PM
Hi i just have the basic chanels package
No its the original box
Ive had no problmes before it just started on monday
No other issues previously
Message posted on 18 Jul 2023 08:59 PM
I don't know what you mean by that. Can you watch channel 106? And if so, does it give the same error when you try to record from channel 106?
Message posted on 18 Jul 2023 09:02 PM
i do have that chanel but when i go on it it says this viewing card is not authorised call the broadcaster for assistance
As in no movies or sports etc just other chanels
Message posted on 18 Jul 2023 09:13 PM
Ah, OK. Have you ordered Sky Q in the past, and subsequently cancelled it?
Message posted on 18 Jul 2023 09:16 PM
Yes they rang me to offer it a few months and i made an appointment but had to cancel as i was working
Message posted on 18 Jul 2023 09:37 PM
Ah ok ... thankyou so much for your help much appreciated
Message posted on 18 Jul 2023 10:02 PM
Hi. I am having this exact same problem but I haven't ordered SkyQ.
I have other Sky+ boxes that are working fine, it's just one that won't let me watch any sports or movie channels, or 106 etc.
