Discussion topic: Hi box lights up but won’t send signal to tv. Reboot doesn’t work
This message was authored by: Mabel67
Message posted on 10 Nov 2025 08:08 AM
There is no signal being sent to the TV from the Sky box. I have removed the card and rebooted several times with no success.
Find out more
Message posted on 10 Nov 2025 08:23 AM
Re: Hi box lights up but won’t send signal to tv. Reboot doesn’t work
@Mabel67 have you checked to see that the correct HDMI input is selected in your tv? Am I correct in understanding that,the power LED on the front panel of your Sky box changes to green when you press the power button on your Sky remote?
