Discussion topic: Having trouble with getting a satellite signal & my sky+ box won’t initialise
This message was authored by: Peter129
Having trouble with the sky+ box still saying it's still initialising & to return later.
can someone tell me is 2weeks a bit long ????!!!!!
no signal either
Re: Having trouble with getting a satellite signal & my sky+ box won’t initialise
30 minutes is a bit to long to initialise let alone two weeks!
What are your Signal Strengths/Qualities? Take a look at the link below:
See question Q11 in my Sky Plus F⋅A⋅Q
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
This message was authored by: Denise+Lee
Not helpful at all
@Denise+Lee wrote:
Not helpful at all
@Denise+Lee wrote:
Not helpful at all
You haven't told us what the problem is yet!
