Discussion topic: Had no satellite signal to sky+ box since Monday. Have been through all on line help but Lock ind
Message posted on 06 Nov 2024 10:02 AM
Have been through all on line help. Lock Indicator is NOT LOCKED and network id is NULL so advised to contact sky but can't get to speak to a human being!!! How can I get an engineer?
Message posted on 06 Nov 2024 10:12 AM - last edited: 06 Nov 2024 10:12 AM
Re: Had no satellite signal to sky+ box since Monday. Have been through all on line help but Lock
Sky no longer provide engineer support for Sky+ equipment, I'm afraid, unless you have Sky Protect. You'll need to engage a local satellite installer to take a look,.
What are your Signal Strengths/Qualities? Take a look at the link below:
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
