Discussion topic: Error message "mini tv unavailable. No satellite signal"
This message was authored by: Karen_Nicholls
We are getting this message across a number of channels and have been for several days so not snow related.  I have of course tried rebooting everything.  Anybother suggestions?
Re: Error message "mini tv unavailable. No satellite signal"
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
@Karen_Nicholls What are your Signal Strengths/Quality?
When tuned to an affected channel,
Press Services > Settings > Signal
All four white bars should be at least half way across.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Avatar for Karen_Nicholls
Hi
Thanks for info.  Have checked and there is no white bar at all on Input 1 strength  / quality.  Any suggestions?
Try unscrewing both dish input cables at the back of the box and swapping them around
@Karen_Nicholls wrote:
Hi
As per @Annie+UK post above it could be any number of things and Sky no longer provide support so you would need to employ a local satellite engineer to investigate and fix.
One thing you could try is, with the box powered off, unscrew the two satellite cables from the back of the box and swap them over, being careful not to damage the central wire, to see if the issue moves to the Input 2 or stays with Input 1 (or miraculously fixes it)
Thanks Annie will give it a go.
