Discussion topic: Compensation for removal of SKY Satellite TV service without any notice.
Re: Compensation for removal of SKY Satellite TV service without any notice.
@MJK-RG41  When replying use the @ and select the person your replying to, you don't need to keep posting the same reply though.
Do you see a "No signal" or "No satellite Signal" message?
If you're not getting any channels it has to be one or the other, as pointed out in previous replies deactivation of a card would still allow FTA  channels (BBC, ITV, CH4, Ch5 etc) to be received.
If you have a "No satellite" signal then your dish needs realigning, Sky no longer support Sky+HD boxes, you would either need to move to Sky Q or Sky stream or get the services of a local installer to re-align your dish.
A "No signal" message is your TV telling you you've selected the incorrect input for your Sky +HD box and you need to scroll through the inputs on your TV remote to select the correct one.
A No signal or No satellite siugn message does not mean Sky have removed your services.
@MJK-RG41 Do you have a Sky HD box or Sky+ HD box or a very old Sky SD box
@MJK-RG41 wrote:
 We just lost all signal, they just disabled our SKY box card at their end, so no more correct decoding of signal, I assume.
That's an incorrect assumption, and not technically possible on Sky+
Sky has however removed subscription service from non-HD Sky+ boxes because there's no longer a broadcast signal which those few remaining antique boxes can receive and so it would be inappropriate to continue billing: that's been advertised on the boxes themselves for more than a year.
Sky has however removed subscription service from non-HD Sky+ boxes because there's no longer a broadcast signal which those few remaining antique boxes can receive: that's been advertised on the boxes themselves for more than a year.
I don't think the OP is listening, presumably because it doesn't fit their agenda.
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
... and whether the box is SD or HD🤔
