Discussion topic: Code for Sky+ remote rev 10 for Amazon Fire TV Omni QLED 50-inch?
This message was authored by: graebah
Can anyone help?
I am trying to find the code for Amazon Fire TV Omni QLED 50-inch to pair with the Sky + remote Rev 10.
Thank you
Re: Code for Sky+ remote rev 10 for Amazon Fire TV Omni QLED 50-inch?
How to program your remote control with no code.
Take a look at the link below:
See question Q43 in my Sky Plus F⋅A⋅Q
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
This message was authored by: ThePope27
@graebah
Try one of these codes if you have a Rev 10 remote, they are for a JVC but one of them should work.
2146
1681
1846
1402
0681
1704
0102
1695
1191
3056
If the above doesn't work try this,
1. Press TV
2. Press and hold Select and Red together until the red LED flashes twice.
3. Press TV, then Standby repeatedly until the TV switches off. As soon as it switches off, press Select to save the code.
This cycles through every code stored on the database chip within the remote, so it can take a while ( potentially a long while!). If it does not find a code, then there is no code stored on your version remote that will operate your tv, and no real chance that an updated remote control will be released by Sky, as SkyQ/Stream is the way forward, not Sky+HD as it is now a deprecated product that is no longer supported by Sky.
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
