Discussion topic: Code for Pairing new sky+ remote to LG55UR81006LJ
This message was authored by: Craig444
Can someone give me the four digit code to pair my new sky+ rev9f remote to my LG tv model 55UR81006 LJ
Re: Code for Pairing new sky+ remote to LG55UR81006LJ
How to program your remote control with no code.
Take a look at the link below:
See question Q43 in my Sky Plus F⋅A⋅Q
I am Neurodivergent My Sky FAQs : Go Stream Glass Plus
@Craig444 have you looked for the code here: https://www.sky.com/help/program-your-remote
Avatar for Craig444
Yes but none work
Avatar for Craig444
Thank you but it didn't work
@Craig444 if you've completed the process @Annie+UK described to no avail, there's no code for your TV in the remote's chipset.  You could try a Rev10 remote, but there's no guarantee that the right code will be there either.
Avatar for Craig444
Some of the codes operate the sound and some operate the channel but none operate both
That's not uncommon.
