Discussion topic: Cinema HD channels not available on old white Sky box.
This message was authored by: Colin+Lovell
I have a Sky+HD box in one room and an older white box in another room. I can get Cinema HD cannels on the Sky+HD box but not on the white box.. Can I change the settings on the white box to get cinema HD channels?  Or must I replace the old white box with another Sky+HD box?
Re: Cinema HD channels not available on old white Sky box.
@Colin+Lovell  You need +HD box to receive HD Channels
Your white box does not have the correct (HD) tuner to be able to recieve HD so there is nothing you can do other than replacing the box for a HD capable one
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for Colin+Lovell
Thank you for your help.
