Discussion topic: Cant download on my sky + box
Message posted on ‎01 Oct 2023 07:26 PM
I spoke to a sky advisor and she told me to clear the deleted programs which I did but it still won't download. I have 3 broadband which runs Netflix and amozon prime no bother,
Message posted on ‎01 Oct 2023 07:43 PM
Re: Cant download on my sky + box
What is happening when you try to download as you haven't said ?
Message posted on ‎01 Oct 2023 07:53 PM
It comes on the planner as download failed, I've tried different programs and trying to download in SD.
Message posted on ‎01 Oct 2023 08:18 PM
Have you tried a planner rebuild:
Press Services on your remote
Select Help
Select Sky+ Rebuild
This should take no longer than 10 minutes, don't do it if you are recording or due to start recording something.
Message posted on ‎01 Oct 2023 08:24 PM
Yes the adviser took me through that..
Message posted on ‎02 Oct 2023 12:33 PM
@Kevlar wrote:
I have 3 broadband
Is that cellular broadband (3/4/5G) ?
Message posted on ‎02 Oct 2023 06:00 PM
Hi.thanks for getting back..its 3g /4g
Message posted on ‎03 Oct 2023 08:41 AM
Download issues with cellular broadband are fairly regularly posted about in this forum, and unfortunately there don't seem to be any particularly good fixes apart from trying different DNS settings.
Message posted on ‎05 Oct 2023 10:04 AM
I've had this issue for months I'm afraid your banging your head against a brick wall as there seems no end game! I've asked here I've contacted Sky direct you go through everything suggested but it just doesn't work, if you ever find a solution please let me know.
A fellow confused Sky subscriber.
Message posted on ‎05 Oct 2023 10:16 AM
Different issue, I suspect, unless you're using a cellular connection too, rather than broadband.
