11 Apr 2020 12:51 PM
I have tried all the codes and my model of sharp an Aquos does appear on the list but won't pair. Just bought a new sky+ remote, any suggestions. Thanks
11 Apr 2020 01:21 PM
Posted by a Superuser, not a Sky employee. Find out moreMany Sharp TVs use an RF remote, not infra red, which isn't compatible with Sky's infra red remote. If you tell us the exact model of your Sharp, we'll be able to tell you if yours is one that's not compatible.
06 Jul 2020 02:10 PM
Having problems pairing my TV with sky remote
Sharp 40UG7252K
06 Jul 2020 02:20 PM
Sharp 40UG7252K
What problem are you having? Code should be 2134.
07 Jul 2020 09:21 AM
Nothing happens when I press. 1&3 together. Nowhere to put code in
07 Jul 2020 09:31 AM
Sounds like a Sky Q remote. You've posted in the Sky+ forum.
The process for programming a Sky Q remote is different. On your Sky box, go to Settings then Setup and remote control and follow the instructions there,
30 Sep 2020 10:44 PM
Also unable to connect Sky q remote to my sharp tv
model; 40BJ2KO
30 Sep 2020 11:21 PM
model; 40BJ2KO
You've also posted in the Sky+ forum. You need the Sky Q forum.
14 Nov 2020 08:25 PM
Hi I'm having trouble pairing my sky remote with my sharp lcd tv. Model is LC-50LM7422K
any help would be great full thanks
14 Nov 2020 08:34 PM
First - is the TV remote an RF remote, rather than IR? If you don't know, fully cover the end of the remote that you would point at the TV with your hand, and see if it still controls the TV. If it does, it's an RF remote, and your Sky remote isn't compatible with your TV.
If it won't operate the TV with the end covered, try the codes here to see if any of them are suitable: https://www.sky.com/help/home/sky-tv/sky-tv-plus/sky-plus-equipment/my-sky-remote/program-your-remot...
08 Dec 2020 09:17 AM
Can't pair sky Q remote handset to sharp tv.
Sharp aquos
model number
55BJ2KE
thanks Julie
08 Dec 2020 09:47 AM
Sharp aquos
model number
55BJ2KE
thanks Julie
It's for the same reason posted earlier - your TV uses an RF remote, not the infra red type that just about every other manufacturer uses. Consequently it's not compatible, with a Sky remote and there's no code that will work.
11 Jan 2021 07:27 PM
Hi I'm struggling to pair my sky control with my sharp lc-40cfe5111k
any help would be appreciated
thanks
11 Jan 2021 07:52 PM
Posted by a Superuser, not a Sky employee. Find out more@rayo1987 see the reply below which also applies to your TV
Sharp aquos
model number
55BJ2KE
thanks Julie
13 Feb 2021 05:28 PM
Does anyone know if you can pair to Sharp LC-43CFE6131K think it may be an RF tv?
Search Sky Community
On average, new discussions are replied to by our users within 100 minutes
