Discussion topic: Can I connect my sky+ box to my smart TVs by av socket
This message was authored by sasa72 This message was authored by: sasa72
My new tv has an av socket can  I connect my sky+ box by this instead of scart which my tv doesn't have
Locked
This message was authored by Mark39 This message was authored by: Mark39
Re: Can I connect my sky+ box to my smart TVs by av socket
Possibly. Does your new tv have yellow, red and white/black input phono (aka RCA) sockets?
sasa72
@Mark39
sasa72
@Mark39  it has pink , white , red , blue and green/yellow
Not entirely sure from the picture tbh. If you can post the tv make and model, it might be possible to find an online spec for it to clarify.
I think that's component-video-in plus L/R audio (similar panel below)  Possibly the green/yellow is intended to indicate that socket also does composite-video-in by itself.
@sasa72 Yes, I think @TimmyBGood is right - in which case you can connect your Sky box using those sockets: yellow to green/yellow, red to red and white to white.
sasa72
@Mark39  & @TimmyBGood  thank you both so much for your help Will try at the weekend with crossed fingers 🤞
Locked
