Discussion topic: Came in from work and my sky box is completely not working. it’s dead. Need an engineer asap
This message was authored by: Poppy54321
My sky box has died.
There is no power to my sky box at all. It's plugged into the same socket as my tv and tv is working but no sky. No lights or anything on front panel.  I need an engineer and most likely a new sky box asap. Thanks
Re: Came in from work and my sky box is completely not working. it’s dead. Need an engineer asap
This forum is primarily customer-to-customer help, you need to contact Sky
I am NeurodivergentMy Sky FAQs : Go Stream Glass Plus
You can't arrange an engineer via here I'm afraid and neither will Sky supply you with another Sky+ box as they will insist on you upgrading to Sky Q. You can purchase a Sky+ yourself from auctions sites and the likes but make sure you select the 890 or 895 models.
